Grafana loki log deletion problem using docker-compose with boltdb-shipper
After deploying Grafana loki in my local machine using docker-compose, The Grafana Loki doesn’t delete the old logs even if we set the retention period.
First I tried to use table manager but it doesn’t work as expected.
table_manager:
  retention_deletes_enabled: true
  retention_period: 72h
Then used a compactor which also doesn't delete the old logs.
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
compactor:
  retention_enabled: true
limits_config:
