Loki is deleting logs of killed/deleted containers before the retention policy
  • What loki version and what operating system are you using?
    loki:2.6.1
    keep logs in the selected namespace for configurable time
    we have configured limits_config
  • What happened?
    Logs are correctly retained for the containers that are still running.
    If the user manually kills or deletes a container these logs are deleted before the configured retain policy.
    All logs linked to containers matching particular selectors should be kept by Loki until the retain policy.
    we are using loki-grafana-agent-operator and helmfiles
loki:
commonConfig:
replication_factor: 1
storage:
type: ‘filesystem’
rulerConfig:
storage:
type: local
auth_enabled: false
limits_config:
retention_period: 168h
retention_stream:
- selector: ‘{namespace=“gate”}’
priority: 1
period: {{ .Values.logging.retentionPeriod | default “744h” }}
monitoring:
selfMonitoring:
lokiCanary:
enabled: false
global:
dnsService: rke2-coredns-rke2-coredns
singleBinary:
persistence:
storageClass: {{ .Values.storage.usage.logs }}
    No errors
    yes but this part is not covered: Retention | Grafana Loki documentation
