I have used the table plugin in which I want to disable the sort option I have tried setting false to desc in sort type but when I click on the table header sorting works I want to disable the sorting option table plugin
Kindly let me know the option to disable it
Thanks
can you include a screenshot of what you’re trying to achieve, and do you think you could try and replicate this on our public sandbox, https://play.grafana.org? ![]()
also grafana version is crucial. This plugin gets a lot of development
Hi Mat,
Pls, find the Grafana sandbox attached in which you could see that when we click on the table header the sorting takes place, I want to disable the sorting that takes place. That’s what I want to achieve but I can’t find any options to disable the sort.
https://play.grafana.org/d/OhR1ID6Mk/3-table?orgId=1
Grafana version that I am using in V8.5.2
Hi Mat,
This is not possible.
Not sure how much this helps, but found this when we are unable to sort based on columns. We spent sometime why we are unable to sort on column headers and at last found this
