I am trying to deploy grafana on AWS EKS cluster and provision an application load balancer to access the grafana over we browser.
Is there any guide or document that i can refer while installation ?
Thank you
HS
Thank you
HS
welcome to the
forum, @hs118505
this is probably a question better suited for the AWS forum.
You can deploy grafana to k8s using a simple yaml file, a helm chart, or other methods like terraform:
