Hello everyone,
I want to install & configure the grafana on aws ec2 instance, for this I go with following cmds
sudo yum update
sudo yum install docker -y
sudo service docker start
sudo docker pull grafana/grafana
sudo docker run -d --name=grafana -p 3000:3000 grafana/grafana
then I try to ec2-13-233-xxxxxxxxxxxxxxxxxxxxxxxxxxx.amazonaws.com:3000 on google page but I am not able to open or login to grafana page . so please help where to correct my mistakes ?
And I edit the inbound rule & 3000 port is opened.
please help then I will very thankful
Best regards
mounika
so better make sure your service is up and fine on first please please
