How to Customize Grafana UI on Windows (Enterprise Version 11.2)
Hi Grafana Community,
I need help with customizing the default Grafana UI to match a specific dashboard design. I’m a Windows user (Windows 11) and have been searching for solutions, but most of the guides I found are for Linux. I’m using Grafana Enterprise version 11.2.
Here are my specific requirements:
  1. Convert Default Grafana UI to a Custom Dashboard Design:
    I want to modify the default Grafana UI to resemble a specific dashboard layout. Any guidance or steps for achieving this on Windows would be greatly appreciated.
  2. Disable Data Source Left Menu for Viewers:
    I want to disable the data source left menu for viewers and restrict their ability to alter it. What’s the best way to do this?
If anyone has experience with these customizations on Windows or can point me to relevant resources, I’d really appreciate your help!
Thanks in advance!
