Hello…Grafana Team I want to create multiple dashboard using dashboard provisioning
in here doc just this
apiVersion: 1
providers:
- name: ‘default’
orgId: 1
folder: ‘’
type: file
disableDeletion: false
editable: false
options:
path: /var/lib/grafana/dashboards
we are using simple-jsone datasbes plugin that’s iwant to ask you how to create more about into dashboard provisioning
can you guide me how to create the multiple dashboard??
Thanks!!!..
Not quite sure I understand what you want to do.
Sounds like you want to provision multiple dashboards into Grafana. If thats the case, you can put all the dashboards into the /var/lib/grafana/dashboards folder and they will be provisioned within Grafana.
If i have multiple dashboards, putting them in separate json files inside /var/lib/grafana/dashboards directory works well. Is there a way we can combine all the dashboard json files into one json file? I tried making list of all the json blocks of dashboard but it didn’t work. Let me know if it is possible to combine all the dashboards in one json file.
