How do I provision multiple provisioned dashboards
Is there a way to provision multiple dashboards in json, by adding more files in the dashboards folder… I am using HELM based deployment and the Grafana version I am trying out is 7.0.0
Yes.
Each needs a unique “title” and “uid” parameter. Other than that, they all go
into the same directory.
Antony.
I was a bit confused at first, as the dashboards took time to show up
