How to create a mapping for result values in a specific column of a table?
Hello Grafana community,
I have the following table below, which comes from a Rest API data source (Infinity Plugin).
I want to replace the value only in the “Status” column. For example, replace Status 3 with XPTO. Is it possible? In the native Grafana function, Mappings, it replaces values in both columns, and it ends up being very confusing.
Thank you.
Welcome
I would use jsonata for infinity and then use ternary operator “? :”.
predicate ? expr1 : expr2
You can use Infinity **Computed column" for this
and with the computed column ( rating == 3 ? 'Good' : ( rating == 4 ? 'Better' : 'Who knows!!' )
and then you can hide rating using the organize fields transformations if you want.
