How to copy a lot of logs from logs panel?
    Grafana v13.0.1 (a100054f)
    I want to copy the logs that are more then in one screen.
    I just try to do text selection with holded left mouse key.
  • What happened?
    After the scrolling down more then one screen the selection is on the full logs.
    Selection just in places where I chosen
    Don’t think that needed
    No
    No
Hello @mihalt , go to grafana explore tab, write your log query (LogQL) or use Builder then run the query. Scroll down and downlode your logs in txt file then copied it.
okay, thank you. But not a way to do it from logs panel in dashboard?
Also, I’ve found that the time doesn’t match in the txt logs with what I see on the web interface on around 3 hours. Looks like that there is Greenwich Mean Time in the txt :frowning:
