How to convert timestamp to date in graph panel title?
I am using Grafana 6.3.2
I want to display the date for a graph panel in the title of the panel.
I was thinking to use the $__from variable. I just cannot find a way to convert this timestamp to the corresponding date considering the browser’s timezone.
Is there such a function that would take timestamp and return date ?
There’s currently no such function for converting variables values
@anon34853223 do you think this is feature request worthy or it is totally beyond the scope?
There’s already a feature request for it, sort of manipulation of variables: https://github.com/grafana/grafana/issues/8259
One possible way to work around this is to define a hidden variable that points to a data source that is able to perform this manipulation. For example, a SQL database with the following:
select cast(cast($__timeFrom() as date) as varchar)
Then reference that variable in the panel title
