I have a table in below format and using Timeseries panel
(Timestamp:datetime, standarddev: float, value: float, name: string)
I want to convert the standarddev into scientific notation and into a label so that the legend looks like below,
value {name="Test", standarddev="1.000E3"}
How can I do?
What kind of data source is it? Could you please provide some obfuscated data samples as csv?
Timestamp,standarddev,value,name
2022-05-06 13:00:00,1.0009,23.4,'Darth Grafini'
Sure. I am unable to share the data as csv. So, I will try to give a sample as you have shared.
2022-05-06 13:00:00,1.118,1.0,'TempAtMax'
2022-05-06 13:00:10,1.118,2.0,'TempAtMax'
2022-05-06 13:00:20,1.118,3.0,'TempAtMax'
2022-05-06 13:00:30,1.118,4.0,'TempAtMax'
So, in the legend, I want,
value {name="TempAtMax", standarddev="1.118E0"}
I am using Azure Data Explorer. If the standarddev is a string, it works. However, I want to visualize it in scientific notation and Azure data explore don’t support formatting numbers.
That is inline csv
csv does not have to be a file you share. What you provided is perfect useable csv
You could use the “Rename by regex” transform. It wouldn’t be a general/scalable solution since you would need to add an explicit transform for each case/exponent, but if the range of the stdev values is only a couple of orders of magnitude, than it’s probably sufficient.
For example, for this data we get:
by using these transforms (for the cases of E0, E1, E-2):
Note that the order of the transforms is important - you need to have the more specific ones first.
