Error info:Login error: unexpected EOF
I need to connect to SQL Server 2000
Grafana ships with built-in support for Microsoft SQL Server (MS SQL). You can query and visualize data from any Microsoft SQL Server 2005 or newer
sql 2000?
On 4/9/2013, Extended Support for SQL Server 2000 will come to an end, and SQL Server 2000 will no longer be supported
