Grafana 9.3.16 in EKS -
Gauge where larger is better, smaller is worse, and thresholds work properly – i.e. larger values are Green, smaller values are Yellow, smallest values are Red. For instance I have one where the current value is 355. I would like it to display yellow below 200, and red below 50. -
Gauge type panel, thresholds … basically I don’t get it at all how I can achieve this -
What happened?
Nothing, can’t find any way to do this -
no -
no -
no, can’t find any in Grafana docs or via internet search
Are you answering some invisible questions we are not seeing? ![]()
