How to configure filed data links in log panel
hi team! i have tried many ways but still cannot jump from my log panel’s filed ‘traceID’ to another trace panel, is this function not supported by log panel or something wrong with my configuration?thanks
I think Logs visualization does not support data links (source). Try to change your visualization to Table and see if your data link works (that might be indication if your data link configuration works, but it seems fine to me).
Tip: if you want to move between grafana dashboards in the same instance, you can drop host and start with /d - Grafana by default will add host at the beginning of the link.
