I want to set one of my dashboards named “General Overview” as home dashboard in custom.ini.
How do i get the path to the dasboard and how should it be added in custom.ini default_home_dashboard_path setting?
Thanks
Thanks
You should export your dashboard as JSON and put it on a local directory then change the setting on your configuration file. It is very well documented here :
Good Luck
Hi, thanks for you help!
It works!
