I’ve been using a grafana docker installation for a while now and have just run into this issue. I had 3-4 different dashboards saved and would test various queries on each before settling in on what I wanted. In one dashboard, I had done so much work that I decided to make that my default dashboard. I removed the previous version and added this new dashboard to the default preferences list. I saved this change and restarted Grafana. Now I do not have any default dashboard show up and have to select one from the Dashboard list.
What have I done wrong?!
I’m using the latest grafana docker version available
When I select HOME from the top of the Dashboard it brings up the one I want but this used to open when I first opened the page.
