I have installed grafana and my backend data source is SQL server. I am retrieving two values from the table and place them in the graph select from the panel.
If you see closely the first bar is showing the value 1935 which is 1926 passed and 6 failed. I want to build a graph which contains the same but the bar should be 2 colors, green for passed and red for failed and they should overlap each other. Please refer the screenshot attached.
My expectation is similar like below image:
