I want to query multi-host load info like node_load1{ip=~$'IP1|IP2|IP3'},
The IP1 IP2 IP3 is the variable IPList (query from JSON Datasource, return a List<string>)
How can I concate the IPList variable with ‘|’ to generate an IP1|IP2|IP3 string to send to Prometheus query API?
PS:
previously I concate the ip list in my JSON datasource API, but it was a poor implemention,Is there a grafana way to concate this ip elegantly?
Thank U, but where can I use this magic?
servers = ['test1.', 'test2']
String to interpolate: '${servers:pipe}'
Interpolation result: 'test1.|test2'
in create variable form? or in panel query?
The doc your post doesn’t have a example
The doc you post is target for generate a variable with concated variable, How do I use ${varList:pipe} in panel graph data query? or can I generate ‘concatedVarList’ by variable ‘varList:pipe’ with grafana?
In the query. Don’t use plain variable:
node_load1{ip=~$'$ipvariable'},
But advanced formatting:
node_load1{ip=~$'${ipvariable:pipe}'},
Use query inspector for any problems to see if variables are interpolated correctly.
thanks, but it seems should be
node_load1{ip=~'${ipvariable:pipe}'},
not
As I said, use query inspector and fix it on your won. My recommendation is based on your initial post:
Wrong input, wrong result.
