Hello all, I’m using PostgreSQL database to do some reports in grafana, I’m a beginner and still learning, and I need help because I don’t know how to connect $__timeFilter and connect data with grafana time range
welcome to the
forum, @aleeulinick
hmmm, have you seen this doc that helps explain global variables?
Hi!
I am facing the same problem.
Can’t find a solution on how to use correctly the $__interval inside PostgreSQL query!
Did you find any solution? Unfortunately even the support didn’t help me here …
Something like this?
SELECT $__timeGroupAlias(heure, $__interval), avg(duree)
FROM public.chronogram
GROUP BY 1
ORDER BY 1
