Hello! I use influxdb as main database to show metrics. So the question is: How can I change the value of x-axis. It shows the time it was uploaded to database. I want to use my own timestamp that i have in database.
this is not possible, InfluxDB has a built in timestamp filed, you need to use that time field
Can you give me advice. How can I solve this?
And can I connect PostgreSQL to Grafana? Thank you for reply)
Use the built in time field in influxdb when you write data
