I am using Grafana cloud (free) in Australia and created few dashboard using Azure Monitor as data source. The default date is mm/dd, can i change it to dd/mm?
If possible then how ?
Where exactly are you hoping to change this time formatting? In the legend or axes?
+1 for this, please.
Grafana hosted on a Pi. tooltips show as YYYY-MM-DD.
Would like to change it to DD-MM-YYYY
Thank you.
@Richard238 you can do by changing the full_date setting in grafana’s configuration settings.
this docker command:
docker run \
-e GF_DATE_FORMATS_FULL_DATE='DD-MM-YYYY HH:mm:ss' \
-p 3000:3000 \
grafana/grafana:latest
will give a tooltip with a date like this:
