How to change "No data" to other texts in table?
Hi everyone, I would like to display other texts when there is no data and I do not know how to do it.
There are some answers about this but non of them work for the table, like:
Thanks!
welcome @yonghezhao
what is your datasource?
Did you try Standard options - No value ?
Hi, thank you for your reply!
The datasource is Athena.
That does not work for me.
I tried. If the table displays an Athena query result, it does not work:
However, if it is an empty table, it works:
