How to change grafana react version?
Hi, I’m creating grafana panel plugin and I’m defining react version as 18, but when used in grafana it uses React version 16. My dependencies need react 18. How can I change it?
Hi.
The method Yosiasz mentioned will work but keep in mind, react is a dependency provided by the Grafana runtime. so even if you manage to change your own grafana development clone to a newer react, if you try to load your plugin in other grafana instances they’ll be using the default one (which at the time of me writing this is 16).
