How to change default exemplars label name traceID in pre-configured Prometheus data source
I’m using Grafana Cloud.
I’d like to configure the Exemplars in the pre-configured Prometheus data source.
In this data source, I can toggle on the “Internal link” option to enable exemplars.
But I can’t change the default Label name from traceID to trace_id
So, I need to create a new Prometheus data source with the same connection information and add the exemplar configuration.
Is there a way to avoid this data source creation and customize the pre-configured data source ?
Thanks
