How to automate the process of adding datasources to grafana using terraform using azure auth instead of basic auth
    Grafana Enterprise edition and Linux OS
    Trying to automate the adding of datasources
    using terraform
  • What happened?
    In the documentation I find only the basic authentication method, whereas I need to azure auth , but I don’t find the properties related to azure auth
    I expect some support from any one who implemented this already
resource "grafana_data_source" "prometheus" {
  type                = "prometheus"
  name                = "mimir"
  url                 = "https://my-instances.com"
  basic_auth_enabled  = true
  basic_auth_username = "username"
  json_data_encoded = jsonencode({
    httpMethod        = "POST"
    prometheusType    = "Mimir"
    prometheusVersion = "2.4.0"
