Some background:
I have a home sprinkler system I created, and I publish the state when it changes.
I have these boolean values from the system. It looks like the “value” in influxdb is 1 or 0. I have a “Running” that is true when any of the zones are on. And I have a Zone 0/Zone 1/Zone 2 that is true if that particular zone is on.
I only publish the change in state to mqtt. Home assistant is pulling the data into influxdb for me.
Here is the actual question:
How do I aggregate that into the number of minutes it was running, or the number of minutes it was running in each zone? I just started logging it, and I can see the on or off state with this query:
SELECT last("value") FROM "state" WHERE ("entity_id" = 'sprinklers') AND $timeFilter GROUP BY time(1m) fill(previous)
But how do I make a graph that would show the last 7 days, and tell me how many minutes I ran each zone, or the total number of minutes it was running?
Thanks for the help.
