How to add worldPing plugin to Grafana 7+ version?
I installed worldPing plugin using grafana-cli and it seemed like it got installed. But I cannot see it in grafana. How do I enable it?
Is there any other plugin in grafana that can be used for monitoring specific API endpoints?
Hi @dulatcollege are you still not able to see the plugin show up after restarting your Grafana instance?
Update: Hi @dulatcollege got confirmation from the engineering team here at Grafana Labs that worldPing is officially deprecated. Synthetic Monitoring is on the way and will be the successor to it. We’ll have more updates to share soon on it, but if you want a preview, check it out here: https://grafana.com/grafana/plugins/grafana-synthetic-monitoring-app
We are closing this topic since there have been no further responses from the author, and it originally referrers to deprecated plugin, which is no longer supported as of the time of this reply.
