How to add the users in the dashboard alert in grafana 9.1 version
welcome to the
community @ravitejachandika
if you meant how to control access to certain dashboards, see this doc:
I trying to add the 3 users to one of my selected dashboards . here i dont have option to add individual users to that particular dashboards alert.
Is there any step-by-step document or tutorial ?
- In the top right corner of the dashboard, click Dashboard settings (the cog icon).
- Click Permissions and then click Add Permission.
- In the Add Permission For dropdown menu, select User
- Select the user
- Select the permission and click Save
Apologies if I am not understanding this fully.
Actuallly i’m trying to configure alert for my dashboard .
i configured the disk usage alert , if the disk avg usage is above 80% then alert email should trigger .
what i have done was
- run the query and created the alert
- In alerts its showing the alert is firing and the health is OK .And i received the alert only one time
- Right now i could see that there are 5 -8 servers which reaches disk usage is above 80% . Still i’m not receiving email alerts .
what to check and what to do ?
And where to find the “Rule-uid” in alerts section and after creating new alert iam not able to view the new rule_uid .
PFA for reference
try setting the alert to evaluate Every 1m for 0s, so you make sure it fires the moment the condiiton is met. I think your current setting Every 1m for 2m is producing unpredictable results because the system is trying to evaluate every 1 minutes, but the for part has not finished its 2 minutes yet.
You can check the uid in the url of your browser when editing the alert rule
example
www.xxxxx.com/alerting/grafana/eK_NbfBVk/
In addition, you should review your notification policy
group wait
group interval
repeat interval
