Hi All,
I need to add the link inside to the text panel and also image .Can anyone suggest me how to do that.
You can do it in HTML format, you just need to choose the html mode as below:
Exactly as @agnestoulet1 has said.
Also, just make sure, that in your custom.ini file you have disable_sanitize_html = true .
More on this:
