v8.5.5 -
Automate adding users in a Grafana instance that has OAuth enabled -
Adding users is done via the Admin API. The admin API only works with Basic Auth. So we created a separate Grafana instance with Basic Auth that shares the same database. This way I can use the Basic Auth of the latter while my actions are reflected on the former.
The script uses the Add a new user to the current organization | Grafana documentation call. -
What happened?
The users do get added, but they are assigned Basic Auth. -
I expect that at least one of the following exists but I’m not aware of:- A parameter such as “authType” in the payload that allows defining which Authentication type the user can use
- An API endpoint for changing the authentication type for an existing user
N/A -
N/A -
I came across some perhaps related threads e.g. here, here, and here, but there were either no answers or they didn’t apply
