How to add LDAP users to a team, before they connect
When using external LDAP auth, users are not shown in Grafana admin panel until they connect once.
It’s a terrible user experience for our users, we ask them to log once, then tell us they do, and after that, we associate them with a team, to give them access to folders and dashboards.
There is many other apps where we can browse LDAP users, not only the synchronised local users.
Did I miss something ?
What can I do, to automate the user sync ? I see that a failed login does not suffice.
I can try to add users in the sqlite DB, but I will probably forget some usefull things…
Another way would be to map LDAP groups with Teams, like it already possible with Organisations.
given the fact that there wasn’t any reply to this since August 2018, I would like to give the topic a little push …
We have exactly the same problem with the user experience, and so I would also be very interested in a configuration option to map LDAP accounts to teams, preferably using LDAP groups as the selector.
Any chance this will be implemented in the forseeable future?
