How to add HTML Code in Grafana 7
Hello guys!
I have been having trouble upgrading from Grafana 6 to 7! I have currently trying to upgrade to the newer version and I did come up with some issues where I am not able to display any HTML anymore. See the attached image:
<center>
<br />
<table style="border: none;">
    <tr style="border: none;">
        <td style="border: none;">
            <select id="kw-type" name="kw-type" class="btn navbar-button gf-timepicker-nav-btn" style="width: 130px;">
                <option value="positive">POSITIVE</option>
                <option value="negative">NEGATIVE</option>
            </select>
        </td>
            <input type="text" id="kw-keyword" name="kw-keyword" class="btn navbar-button gf-timepicker-nav-btn" style="text-align: left;" />
        </td>
    </tr>
    <tr>
        <td colspan="2" style="border: none; text-align: center;">
            <center>
                <button
                    onclick="insertKeywords(1,document.getElementById('kw-type').value,document.getElementById('kw-keyword').value,'popup','refresh');document.getElementById('kw-keyword').value=''"
                    Add to watchlist
                </button>
            </center>
        </td>
    </tr>
</table>
</center>
and it worked fine when I had it in Grafana 6 but now as you can see it only displays the code now.
I wonder how I can add HTML Code in grafana like I had it in 6 before :cry:
Hi @barryaljawari
This still works. Here is your html code on my local instance running Grafana 8.0.2:
There was a lot of work done on the Text Panel between Grafana 6 and 7.
Have you set disable_sanitize_html to true in your configurations? You need to do that starting with v7:
docker run -d -p 3000:3000 "GF_PANELS_DISABLE_SANITIZE_HTML=true" grafana/grafana:8.0.2
NOTE:
The default is false because this setting leaves you more exposed to XSS attacks (see PR for larger discussion)
