[How To] Add Data Links to multiple graphs at once
I have added data links to a bar gauge chart thats part of a larger dashboard. There are many similar charts in the dashboard that I’d have to manually setup data links for. There must around 20-30 charts in total in this particular dashboard.
Is there a way for me to set up a rule or some way to bulk add data links to all these dashboards?
The field labels will be the same hence the data links are the same.
