How to add CSS to environment to change the color?
I’m using Grafana v9.5.1. I want to change the color of the entire environment. I know there are UI themes, but I want to use a custom color. I figure using CSS is the best way to go because Boom Theme Plugin is deprecated. How can I accomplish this?
As of right now you cannot create custom themes.
