How to add a template value to the Dashboard URL on unified alerts
    grafana v8.3.4 on Red Hat Enterprise Linux release 8.3
    I want to add an alert label from a multidimensional rule to the DashboardURL alert field
    Setting the string below to the Dashboard UID:
NG-8Ioank/simpledashboard?orgId=1&var-PlatformVar={{ $labels.platform }}
  • What happened?
    The ? character is escaped to the hex (%3F) value on the alert so the address is changed to a wrong parameterized URL:
NG-8Ioank/simpledashboard%3ForgId=1&var-PlatformVar=Platform1
    I expected to have the parameterized URL inside the DashboardURL
I also tried to use the DashboardURL variable inside the alarm RunBook URL info, so I can use the autogenerated Dashboard URL, but that variable is not expanded on the alert:
{{ DashboardURL }}/simpledashboard?orgId=1&var-PlatformVar={{ $labels.platform }}
I can set the full URL into Runbook URL instead of using the DashboardURL but then I have to know the URL where grafana is running on.
Looks like you’ve done pretty thorough research on this @togarha
I might make a GH issue about this and share your reseach:
Created already:
Hey there, I came across this question while working on a related example in the docs:
:blue_book: Print a link to a dashboard with time range.
This example can be useful if you’re looking to construct a dashboard URL that includes from and to time range parameters in your alert notifications.w
