We are building a panel plugin where we would like to have access to the dimensions of the panel in the Panel Editor. More specifically, on a CustomEditor.
What we tried:
plugin.panel?.defaultProps?.height
The above code is in the module.tsx (Panel Editor file)
No other good idea came up so far. Any idea where we could find these values?
It’s not specifically the size of the panel editor, but if you want to know the size of a component to for example resize it properly, you can use AutoSizer:
However I may have not expressed my question properly or I’m not knowledgeable enough to understand. Please allow me to ask again:
I would like to access the Panel Plugin width and height inside the panel editor. I do not plan to write or change the sizes so any “hack” would do (i think). The true purpose is that I want to get the content of the plugin (image that fills whole plugin) so that i can draw a polygon.
Regarding where I want to draw the polygon, that will be a Modal only available in the Panel Editor. The modal is supposed to have the same dimensions as the Panel (outside of the editor, in the true dashboard).
As you have shown, getting the width and height of the panel is done through the Props and it’s quite forward. But what we are trying to accomplish is to have a Modal (only available in the editor) which will draw a canvas of the same size of the panel (and this size is the one “outside” of editing).
I understand that its super specific and again, it seems my question had flaws or was not understandable what our aim was.
To sum it up: is there a way to get the panel width and height (the dimension in the dashboard) through panel editor?
Maybe our approach is not “best practice” but the reason why the width and height should be the same is to map the polygon edges 1 for 1. I guess all will break apart as soon as we resize the panel later so i might need to save the original width and height that was used on the modal and then do math to translate the new edges.
Regardless on how things go, I appreciate your help.
Thank you @marcusolsson for the help. We opted out for “simplicity” and regardless on the panel dimensions, we are going to calculate polygon coordinates. We didn’t get to try your solution but I am guessing it works fine. I’ll accept your answer as solution for next person to look for answers to see it and we can close this topic. Thank you once again for the help.
