How loki replicate logs?
As I understand, log replication occurs on the distributor level on write.
Does loki have background replication?
I have 3 replicas(also replication_factor: 3). How will loki handle the fall(or manual shutdown) of one of the replicas? Will all logs be available on all 3 replicas eventually?
Loki version: 2.2
Config:
Config
target: all
http_prefix: “”
server:
http_listen_address: “”
http_listen_port: 3100
http_listen_conn_limit: 0
grpc_listen_address: “”
grpc_listen_port: 9095
grpc_listen_conn_limit: 0
http_tls_config:
cert_file: “”
key_file: “”
client_auth_type: “”
client_ca_file: “”
grpc_tls_config:
cert_file: “”
key_file: “”
client_ca_file: “”
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30s
http_server_write_timeout: 30s
http_server_idle_timeout: 2m0s
grpc_server_max_recv_msg_size: 4194304
grpc_server_max_send_msg_size: 4194304
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 5m0s
grpc_server_ping_without_stream_allowed: false
log_format: logfmt
log_level: info
log_source_ips_enabled: false
log_source_ips_header: “”
log_source_ips_regex: “”
http_path_prefix: “”
distributor:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
host: localhost:8500
acl_token: “”
http_client_timeout: 20s
consistent_reads: false
watch_rate_limit: 1
watch_burst_size: 1
etcd:
endpoints:
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: “”
tls_key_path: “”
tls_ca_path: “”
tls_server_name: “”
tls_insecure_skip_verify: false
multi:
primary: “”
secondary: “”
mirror_enabled: false
mirror_timeout: 2s
heartbeat_period: 5s
heartbeat_timeout: 1m0s
instance_id: mon-loki-0
instance_interface_names:
- eth0
- en0
instance_port: 0
instance_addr: “”
querier:
query_timeout: 1m0s
tail_max_duration: 1h0m0s
engine:
timeout: 5m0s
max_look_back_period: 30s
max_concurrent: 20
ingester_client:
pool_config:
client_cleanup_period: 15s
health_check_ingesters: true
remote_timeout: 5s
grpc_client_config:
max_recv_msg_size: 104857600
max_send_msg_size: 16777216
grpc_compression: “”
rate_limit: 0
rate_limit_burst: 0
backoff_on_ratelimits: false
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: “”
tls_key_path: “”
tls_ca_path: “”
tls_server_name: “”
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: “”
watch_rate_limit: 1
watch_burst_size: 1
etcd:
endpoints:
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: “”
tls_key_path: “”
tls_ca_path: “”
tls_server_name: “”
multi:
primary: “”
secondary: “”
mirror_timeout: 2s
zone_awareness_enabled: false
num_tokens: 128
observe_period: 0s
join_after: 0s
min_ready_duration: 1m0s
interface_names:
- eth0
- en0
final_sleep: 30s
tokens_file_path: “”
availability_zone: “”
unregister_on_shutdown: true
address: “”
port: 0
concurrent_flushes: 16
flush_check_period: 30s
flush_op_timeout: 10s
chunk_retain_period: 1m0s
chunk_idle_period: 3m0s
chunk_block_size: 262144
chunk_target_size: 0
chunk_encoding: gzip
max_chunk_age: 1h0m0s
sync_period: 0s
sync_min_utilization: 0
max_returned_stream_errors: 10
query_store_max_look_back_period: 1h28m0s
wal:
enabled: false
dir: wal
checkpoint_duration: 5m0s
flush_on_shutdown: false
replay_memory_ceiling: 4294967296
storage_config:
engine: chunks
aws:
dynamodb:
dynamodb_url: “”
api_limit: 2
throttle_limit: 10
metrics:
url: “”
target_queue_length: 100000
scale_up_factor: 1.3
ignore_throttle_below: 1
queue_length_query: sum(avg_over_time(cortex_ingester_flush_queue_length{job=“cortex/ingester”}[2m]))
write_throttle_query: sum(rate(cortex_dynamo_throttled_total{operation=“DynamoDB.BatchWriteItem”}[1m]))
by (table) > 0
write_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation=“DynamoDB.BatchWriteItem”}[15m]))
by (table) > 0
read_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation=“DynamoDB.QueryPages”}[1h]))
by (table) > 0
read_error_query: sum(increase(cortex_dynamo_failures_total{operation=“DynamoDB.QueryPages”,error=“ProvisionedThroughputExceededException”}[1m]))
by (table) > 0
chunk_gang_size: 10
chunk_get_max_parallelism: 32
backoff_config:
min_period: 100ms
max_period: 50s
max_retries: 20
s3: “”
s3forcepathstyle: false
bucketnames: “”
endpoint: “”
region: “”
access_key_id: “”
secret_access_key: “”
insecure: false
sse_encryption: false
http_config:
idle_conn_timeout: 1m30s
response_header_timeout: 0s
signature_version: v4
sse:
type: “”
kms_key_id: “”
kms_encryption_context: “”
azure:
environment: AzureGlobal
container_name: cortex
account_name: “”
account_key: “”
download_buffer_size: 512000
upload_buffer_size: 256000
upload_buffer_count: 1
request_timeout: 30s
max_retries: 5
min_retry_delay: 10ms
max_retry_delay: 500ms
bigtable:
project: “”
instance: “”
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: true
tls_cert_path: “”
tls_key_path: “”
tls_ca_path: “”
tls_server_name: “”
table_cache_enabled: true
table_cache_expiration: 30m0s
gcs:
bucket_name: “”
chunk_buffer_size: 0
request_timeout: 0s
cassandra:
addresses: “”
port: 9042
keyspace: “”
consistency: QUORUM
disable_initial_host_lookup: false
SSL: false
host_verification: true
CA_path: “”
tls_cert_path: “”
tls_key_path: “”
auth: false
username: “”
password: “”
password_file: “”
custom_authenticators:
timeout: 2s
connect_timeout: 5s
reconnect_interval: 1s
max_retries: 0
retry_max_backoff: 10s
retry_min_backoff: 100ms
query_concurrency: 0
num_connections: 2
convict_hosts_on_failure: true
table_options: “”
boltdb:
directory: “”
filesystem:
directory: /data/loki/chunks
swift:
auth_version: 0
auth_url: “”
username: “”
user_domain_name: “”
user_domain_id: “”
user_id: “”
password: “”
domain_id: “”
domain_name: “”
project_id: “”
project_name: “”
project_domain_id: “”
project_domain_name: “”
region_name: “”
container_name: “”
max_retries: 3
connect_timeout: 10s
request_timeout: 5s
index_cache_validity: 5m0s
index_queries_cache_config:
enable_fifocache: false
default_validity: 0s
background:
writeback_goroutines: 10
writeback_buffer: 10000
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: “”
service: memcached
addresses: “”
timeout: 100ms
max_idle_conns: 16
update_interval: 1m0s
consistent_hash: true
circuit_breaker_consecutive_failures: 10
circuit_breaker_timeout: 10s
circuit_breaker_interval: 10s
redis:
endpoint: “”
master_name: “”
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
password: “”
tls_enabled: false
idle_timeout: 0s
max_connection_age: 0s
fifocache:
max_size_bytes: “”
max_size_items: 0
validity: 0s
prefix: store.index-cache-read.
delete_store:
store: “”
requests_table_name: delete_requests
table_provisioning:
enable_ondemand_throughput_mode: false
provisioned_write_throughput: 1
provisioned_read_throughput: 300
write_scale:
enabled: false
role_arn: “”
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: “”
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
tags: {}
grpc_store: {}
max_chunk_batch_size: 50
boltdb_shipper:
active_index_directory: /data/loki/boltdb-shipper-active
shared_store: filesystem
cache_location: /data/loki/boltdb-shipper-cache
cache_ttl: 24h0m0s
resync_interval: 5m0s
query_ready_num_days: 0
chunk_store_config:
chunk_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: “”
service: memcached
addresses: “”
timeout: 100ms
max_idle_conns: 16
redis:
endpoint: “”
master_name: “”
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
password: “”
tls_enabled: false
idle_timeout: 0s
fifocache:
max_size_bytes: “”
max_size_items: 0
validity: 0s
prefix: store.chunks-cache.
write_dedupe_cache_config:
background:
writeback_goroutines: 0
writeback_buffer: 0
memcached:
expiration: 0s
batch_size: 0
parallelism: 0
memcached_client:
host: “”
service: “”
addresses: “”
timeout: 0s
max_idle_conns: 0
update_interval: 0s
consistent_hash: false
circuit_breaker_consecutive_failures: 0
circuit_breaker_timeout: 0s
circuit_breaker_interval: 0s
redis:
endpoint: “”
master_name: “”
timeout: 0s
expiration: 0s
db: 0
pool_size: 0
password: “”
tls_enabled: false
idle_timeout: 0s
fifocache:
max_size_bytes: “”
max_size_items: 0
validity: 0s
prefix: “”
cache_lookups_older_than: 0s
max_look_back_period: 0s
schema_config:
configs:
    store: boltdb-shipper
    object_store: filesystem
    schema: v11
    index:
    prefix: index_
    period: 1d
    tags: {}
    chunks:
    prefix: “”
    period: 0s
    tags: {}
    row_shards: 16
    limits_config:
    ingestion_rate_strategy: local
    ingestion_rate_mb: 4
    ingestion_burst_size_mb: 6
    max_label_name_length: 1024
    max_label_value_length: 2048
    max_label_names_per_series: 30
    reject_old_samples: true
    reject_old_samples_max_age: 168h0m0s
    creation_grace_period: 10m0s
    enforce_metric_name: false
    max_line_size: 0
    max_streams_per_user: 10000
    max_global_streams_per_user: 0
    max_chunks_per_query: 2000000
    max_query_series: 500
    max_query_lookback: 0s
    max_query_length: 0s
    max_query_parallelism: 14
    cardinality_limit: 100000
    max_streams_matchers_per_query: 1000
    max_concurrent_tail_requests: 10
    max_entries_limit_per_query: 5000
    max_cache_freshness_per_query: 1m0s
    split_queries_by_interval: 0s
    ruler_evaluation_delay_duration: 0s
    ruler_max_rules_per_rule_group: 0
    ruler_max_rule_groups_per_tenant: 0
    per_tenant_override_config: “”
    per_tenant_override_period: 10s
    table_manager:
    throughput_updates_disabled: false
    retention_deletes_enabled: true
    retention_period: 180d
    poll_interval: 2m0s
    index_tables_provisioning:
    provisioned_write_throughput: 1000
    write_scale:
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    read_scale:
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    enable_inactive_throughput_on_demand_mode: false
    inactive_write_throughput: 1
    inactive_read_throughput: 300
    inactive_write_scale:
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    inactive_read_scale:
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    inactive_write_scale_lastn: 4
    inactive_read_scale_lastn: 4
    chunk_tables_provisioning:
    write_scale:
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    read_scale:
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    enabled: false
    role_arn: “”
    min_capacity: 3000
    max_capacity: 6000
    out_cooldown: 1800
    in_cooldown: 1800
    target: 80
    frontend_worker:
    frontend_address: “”
    scheduler_address: “”
    dns_lookup_duration: 10s
    parallelism: 10
    match_max_concurrent: false
    grpc_client_config:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
    min_period: 100ms
    max_period: 10s
    max_retries: 10
    tls_enabled: false
    tls_cert_path: “”
    tls_key_path: “”
    tls_ca_path: “”
    tls_server_name: “”
    frontend:
    log_queries_longer_than: 0s
    max_body_size: 10485760
    query_stats_enabled: false
    max_outstanding_per_tenant: 100
    compress_responses: false
    downstream_url: “”
    tail_proxy_url: “”
    ruler:
    external_url: “”
    ruler_client:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
    min_period: 100ms
    max_period: 10s
    max_retries: 10
    tls_enabled: false
    tls_cert_path: “”
    tls_key_path: “”
    tls_ca_path: “”
    tls_server_name: “”
    evaluation_interval: 1m0s
    poll_interval: 1m0s
    storage:
    type: configdb
    configdb:
    configs_api_url: “”
    client_timeout: 5s
    tls_cert_path: “”
    tls_key_path: “”
    tls_ca_path: “”
    tls_server_name: “”
    azure:
    account_name: “”
    account_key: “”
    max_retries: 5
    gcs:
    bucket_name: “”
    request_timeout: 0s
    s3:
    s3: “”
    bucketnames: “”
    endpoint: “”
    region: “”
    access_key_id: “”
    insecure: false
    http_config:
    sse:
    type: “”
    kms_key_id: “”
    swift:
    auth_version: 0
    auth_url: “”
    username: “”
    user_domain_id: “”
    user_id: “”
    password: “”
    domain_id: “”
    domain_name: “”
    project_id: “”
    project_name: “”
    region_name: “”
    container_name: “”
    max_retries: 3
    request_timeout: 5s
    local:
    directory: “”
    rule_path: /rules
    alertmanager_url: “”
    enable_alertmanager_discovery: false
    alertmanager_refresh_interval: 1m0s
    enable_alertmanager_v2: false
    notification_queue_capacity: 10000
    notification_timeout: 10s
    alertmanager_client:
    tls_cert_path: “”
    tls_key_path: “”
    tls_ca_path: “”
    tls_server_name: “”
    basic_auth_username: “”
    basic_auth_password: “”
    for_outage_tolerance: 1h0m0s
    for_grace_period: 10m0s
    resend_delay: 1m0s
    enable_sharding: false
    sharding_strategy: default
    search_pending_for: 5m0s
    ring:
    kvstore:
    store: memberlist
    prefix: rulers/
    consul:
    acl_token: “”
    watch_rate_limit: 1
    watch_burst_size: 1
    etcd:
    endpoints:
    dial_timeout: 10s
    max_retries: 10
    tls_enabled: false
    tls_cert_path: “”
    tls_key_path: “”
    tls_ca_path: “”
    tls_server_name: “”
    multi:
    primary: “”
    secondary: “”
    mirror_timeout: 2s
    • eth0
    • en0
      instance_port: 0
      instance_addr: “”
      num_tokens: 128
      flush_period: 1m0s
      enable_api: false
      query_range:
      split_queries_by_day: false
      align_queries_with_step: false
      results_cache:
      cache:
      background:
      memcached:
      expiration: 0s
      batch_size: 1024
      parallelism: 100
      memcached_client:
      host: “”
      service: memcached
      addresses: “”
      timeout: 100ms
      max_idle_conns: 16
      redis:
      endpoint: “”
      master_name: “”
      timeout: 500ms
      expiration: 0s
      db: 0
      pool_size: 0
      password: “”
      tls_enabled: false
      idle_timeout: 0s
      fifocache:
      max_size_bytes: “”
      max_size_items: 0
      validity: 0s
      prefix: frontend.
      compression: “”
      cache_results: false
      max_retries: 5
      parallelise_shardable_queries: false
      runtime_config:
      period: 10s
      file: “”
      memberlist:
      node_name: “”
      randomize_node_name: true
      stream_timeout: 0s
      retransmit_factor: 0
      pull_push_interval: 0s
      gossip_interval: 0s
      gossip_nodes: 0
      gossip_to_dead_nodes_time: 0s
      dead_node_reclaim_time: 0s
      join_members:
  • mon-loki-headless:7946
    min_join_backoff: 1s
    max_join_backoff: 1m0s
    max_join_retries: 10
    abort_if_cluster_join_fails: true
    rejoin_interval: 0s
    left_ingesters_timeout: 5m0s
    leave_timeout: 5s
    message_history_buffer_bytes: 0
    bind_addr:
    bind_port: 7946
    packet_dial_timeout: 5s
    packet_write_timeout: 5s
    tracing:
    enabled: true
    compactor:
    working_directory: /data/loki/boltdb-shipper-compactor
    compaction_interval: 2h0m0s
Hi @mikxail
Please see Components | Grafana Loki documentation
This should contain all the context you need
Feel free to follow up if you have further questions
