How Grafana use MySql as configuration database
We’re going to use MySql as Grafana configuration database and deploy a MySql server community version for user. We need to evaluate the license of MySql server deployment. As a result I’d like to know these info: How MySql is connected and used in Grafana? For example, is ODBC or other non-GPL module used?
Thanks!
No special feature on mysql is used from grafana, you can use the standard edition.
You can already try it by your self, Here is a simple script for migrating :
Hope it helps.
Good Luck
