My project uses Grafana to pull Cloudwatch metrics directly, without using a database, I’m unsure of the cost, which seems quite high, as do the number of API calls
Does Grafana make an API call for each point of data, old and new?
i.e. each time a dashboard updates it consumes an API request for every point of data fetched by the dashboard?
Does it also consume Cloudwatch API calls to work out alerts? (calls the same data again to work out triggering alarms)
