How do you monitor processes on Linux like nagios with Alloy and discovery.process
    12.0
    Monitor all processes on Redhat like metrics and let user to choose what they want to set alert with.
    I set this in Alloy configuration, it is a local installed environment without any container.
discovery.process “all” { }
prometheus.scrape “scrape_processes” {
targets = discovery.process.all.targets
prometheus.remote_write “local_system” {
endpoint {
url = “"
headers = {
“X-Scope-OrgID” = "
tls_config {
insecure_skip_verify = true
  • What happened?
    I got “no address” error for the “scrape_processes” in journalctl log file
    I expect to see processes show up in data source.
    As above.
    discovery.process | Grafana Alloy documentation
I have the same issue, is anybody found the solution for this?
