How do I push string value metrics to InfluxDB on Grafana Cloud?
I would like to send a payload in Point format:
curl -X  POST -H  "Authorization: Bearer <Auth_INFO>" -H  "Content-Type: text/plain" "https://influx-prod-13-prod-us-east-0.grafana.net/api/v1/push/influx/write" -d 'conversation_created,source=local conversation_uuid="test"'
The endpoint returns a 204, but the metric never appears in the explorer.
This seems to be a known limitation - how do I get around that issue?
Hey, Yeah don’t think storing string as a metric value is supported in Prometheus itself.
I’d probably send this value as a log if its just a string (You’d be able to do better aggregations also IMO)
