- Gafana v 8
I’m trying to get a scatter plot to see the relationship between two variables using influxdb as a datasource
I have an influxdb measurement that has two fields, hpower (heating power) and utemp (outside temperature). If I format this as a table I get them as two columns.
I have tried using the “scatter” plugin that states it needs data in columns but that does not work, it just insists on putting time on x-axis and the field names in the config are not populated with the field names from my query
I expected that I would be able to select one column as X and one column as Y and it would show my scatter. This has worked before I remember having a 3 dimansional scatter plot between 3 different variables. This stopped working in Grafana 8
So, short question, how do I get a scatter plot using influxdb in grafana 8?
