How do I configure it to click on a value in the table to copy it?
I have a Grafana table with some content that is often copied and pasted elsewhere. How can I configure the single click copy functionality for these cells?
Is this a currently unavailable feature?
Anything help?
You might be able to use the query inspector data result tab it should show it as csv
I usually just enter a value in Grafana, then retrieve that row from a dynamically fetched table, and then need to copy a couple other values from that row and enter them elsewhere. Exporting the csv is rather more complicated.
