How do I change time precession in a template query?
For some reason I need the specific time of a max value in the last 30 days. When I run a query in influxdb I get the correct time and the max value. But when I run the same query in grafana templating query my value is 6 digits too short.
I think I have to specify the time precession. How can I do that?
Any help is welcome :slight_smile:
I don’t think it’s possible to change the time precision. Maybe you can multiply the value with 100000 before using it in metric queries?
If you find that this is a bug, you may report a bug issue at it at Grafana github repo.
Marcus
