How change name of the Axis X
Hi
Is it possible to change name on Axis X from date to week ? (Time Series)
Example:
From 2021-08-02 to 2020_31
Hi @deejayluk ,
It’s possible to do that via Query, just group time variable by week.
PostgresSQL example:
date_trunc('week',reporting_date)::date as time,
Regards,
Sergejs
how do this on the ms sql query?
could you paste your chart?
do it as an override - standard unit
time: YYYY_DD
result
thank you, but still this not show weeknumber and this is only visible when mouse hover on the bars
correct, the override only when you hover/tooltip it. I didnt read your question properly.
I just saw your image post with hover / tooltip
