How can template variable override timepicker
I have a month template variable that I want to use to control the time picker to select the entire month. Please find screen shot attached.
So that my whole dashboard refreshes with the change of the $Month variable and Graph panels X-axis changes with it . So I can visualize the values for each month using the $Month variable.
Hi @agnip,
Have you got the solution for the same? Could you please explain it if you have solution for this?
