Can we create our own time variable?
    Latest version of grafana and os is windows
    I am trying to create my own time variable
    using variable, values in variable are ‘this week’, ‘this month’, ‘this year’, etc
  • What happened?
    I am not able to use those values in my SQL query
Hi @mayurvidhwani7387, can you clarify what you’re trying to achieve? Do you want to have a template variable that has a drop-down with text like “this month”, but then values that correspond to the actual bounds of the month, which you can use in a query?
Are you not able to simply use Grafana’s existing time selector? Maybe you can say a few words about why that doesn’t work for you.
Actually, the task which I have been assigned requires me to create our own time variable and not use the Grafana time filter.
Is it possible to create it in Grafana?
I don’t think there’s a great way to recreate the functionality of the time picker using template variables.
There may be a workaround that involves a key-value variable but it would be complex, ugly, and fragile, and I wouldn’t recommend it. Might be better to rethink the necessity of doing this.
