There is a plugin (graph) with the name old graph unfortunately I cannot find this graph in my grafana . Also I wanted to download it from website and import in grafana but it mentions this graph has resided by default on grafana . Now want to know Where can I download it (json or zip or ,) and import it in my grafana environment ?
Hi @alex23,
Is there a particular reason to use Graph (old) instead of Time series? If you imported a dashboard that uses Graph (old) you can just change them into time series and panels should work (prior to that check if there are any threshold line specified and remove them).
Best regards,
ldrascic
Thanks . But as i said I want to know what is the solution ? How can import old graph ?
