How can i use @grafana/ui in CRA?
Is @grafana/ui designed for only using grafana?
I want to use this library in my project (Create React App)
Reproduce
$ npx create-react-app my-app
$ cd my-app && yarn add @grafana/ui
import logo from './logo.svg';
import './App.css';
import {Alert} from '@grafana/ui'
function App() {
  return (
    <Label description="Option description">Option name</Label>
export default App;
$ yarn start
Error message here
Error: Invalid hook call. Hooks can only be called inside of the body of a function component. This could happen for one of the following reasons:
1. You might have mismatching versions of React and the renderer (such as React DOM)
2. You might be breaking the Rules of Hooks
3. You might have more than one copy of React in the same app
See https://fb.me/react-invalid-hook-call for tips about how to debug and fix this problem.
I have the same problem. Is there any news here?
Stuck with the same problem. Were you able to integrate??
